new to rc and have questoins
ok i bought the traxxis russler and my moror went bad so i got the brushless up grade i am cuerntly running a 7.4 volt batt and i have speed but i want wheelies and power insted should i go get a 11 volt batt or can i gear it for power and wheelies? im brand new to this thanks for any help.
easiest solution, reduce pinion teeth or even change to lipo 7.4 batteries.
11.1v batteries definitely works but its too risky as i've seen lots of people stripping gears or even completely destroy out drives and coupler.
well i see your runing a li-po 7.4v batt already so try tighten the slipper clutch all the way down and if that don't work try a smaller pinon gear,then if that don't work then try a 11.1v plus make shure your esc is runing in 100% forword and 100% backwards mode.But yes 11.1v will give you guaranteed wheelies.
22/86 w/3s 5250 Lipo= Wheelies and speed for sure
Super Moderator
Trader Rating: 31 (100%+)
Tamiya TNX 5.2R
Is it just me..or do these things eat clutch's..??..and anything else I should look out for..???..Seems this thing likes to eat parts....!!!
Any warnings...or help would be greatly appreciated,,
Cheers
Cheers
