Nitro Fuel Mix
Nitro Fuel Mix
Hi All,
I just bought my first Nitro RC Car, and i need help with the Nitro Fuel.
I could only find a nitro fuel of 10 % nitro with 18% oil. can i use this, as the manual of the Car says 15 Nitro mix. Please help.
Super Moderator
Trader Rating: 31 (100%+)
Yes you can, it just won't have as much power as say 15% 0r 20%...you will have to re-tune the motor for different percentages of nitro when or if you get something else. Even different brands of fuel will change the tune of the motor.
Super Moderator
The most common is probably going to be 20% these days... make sure you are buying nitro fuel for "cars"! Airplane fuel uses far less oil and can easily damage you motor!
Jerome
Thank you all for your help, I went to my local hobby store and they were able to find nitro fuel for the car of 20% Nitro and 16 % oil. I made the break-in for the engine today.. All went well after 5 tanks. My problem now, when i was cleaning the car, i found some sand inside the opening after the air filer, what should i do to get rid of it.
Thanks once more for all your support
