X-Ray T1 evo 2 or T1 Factory?
I need to know wich car is the best bacouse i have them both by accident....
I only recently started racing again and ended op having 2 almost complete sets or rc gear.
Ive build the best stuff on the evo2 becouse i thought it was less old of the two.
Another question... What should i do? Buy a new speedcontroller for brushless and normal engines or just one for normal engines? I need to buy one so i just need to know if its worth its money.
I would personally keep the FK because i just like FKs. There really shouldnt be much difference between FK and Evo2. Evo2 can take pivot ball suspension which makes it easier to change caster. I think thats about it.
"Buy a new speedcontroller for brushless and normal engines or just one for normal engines?" im not quite getting you on this one. If you mean either a brushed speed control vs brushless speed control, then it depends on if you would like to upgrade to brushless in the future. If you arent then go for the brushed speed control. Personally i would just go with a brushless setup from the get go.
If you go with a LRP Sphere ESC, then you are set for both Brush and Brushless
Here is the link: http://www.lrp-electronic.de/e/lis/
Yes, they are expensive, but they will last and last...
