What Does A Bad Motor Bearing Sound Like?
Hi Y'all!
I've got a motor that accidentally sucked in a good amount of dust and started being loud when it runs. I've already dissembled and cleaned it. Here's a video I made. The first motor is a healthy motor for reference. The 2nd motor is the one being loud, My guess is bad bearings, but I want to get some input before trying to hunt down and replace them. So yeah, would love to hear if anyone has any experience with this.
Thanks!
youtu.be/f4Rw7IY4Q7c
Thanks!
Bad engine bearings sound like a growling almost grinding type of noise that is loudest on acceleration. Some people actually mistake bad engine bearings for a gear mesh problem - similar type of sound.
Bad bearings can make a grinding sound, but they can also make a trilling sound that almost sounds like the "bullet ricochet" sound used in old western movies -- except a bad bearing will make that sound continuously instead of for a split-second. It's unmistakable; once you've heard a bad bearing making the sound I describe, you'll never be able to overlook it again.
If they ate enough dust that you can hear them just change them out. It's not hard or expensive.
