Tire Flat Spot
Tire Flat Spot
legend has it, that when you leave your RC vehicle sitting on its tires and not on stands for storage, your tires will have flat spots. Is this flat spots permanent or it will go back to normal? Is this even a thing?
permanent.
Never.. I have semi repaired guys that did but never a foam. just a rubber type tire with n without foams.. a hair dryer does alot... 1st I rubbed on some rubber restorer then on low with very limited high fan n heat slowly heat it with a damp sponge on standby also I was outside..
Legend has it right. Flat spot they will. My trucks are stored with the tires attached. The chassis is supported underneath with either a wood 2x4 or 2x6 to keep the tires from grounding. Good luck and welcome to R/C. Cheers. 'AC'
