Shock oiling questions
A freind of mine gave me an old losi xxx-nt and the shocks were pretty dry. Questions is, I used 40wt on all 4 of them. Can you push the shaft all the way in with ease?
Right now it only goes in about half and inch or so then it dosent go in anymore.
Am I doing something wrong or this is how these shocks work?
best thing to do is to take them completely apart.... the rubber seals are probably going to need replacing.
when you do take them apart you will most likely find rubber tubing around the shock shaft.. this is done to limit the shock travel so the truck doesnt bottom out.
I did see that rubber ring. How can you tell if its bad? or do you usually replace it when you change the shock oil?
i replace the Oring every 3-4 rebuilds (any more is just over kill), or before a major race when the car gets a full stripdown, empty the old shock oil out, cleen all the old and any dirt out (if theres dirt inside the shocks replace the seals and get a new piston) fill up to about 3/4 of the way up the shock, ,move the shaft up and down slowly to ensure all air is out from under the piston, fill the shock up untill the oil sits just below the top of the shock, put the cap on and make sure it rebounds all the way if it dosent add a few more drops of oil each time till it does
