Matching your RC's POWER
I have been looking into how to match my motor, with my ESC with my servo and battery so they will all run well! how are you doing the match to make sure everything works together.. I have read in some articles to start with your motor but it calls for what the kv value is but im finding that certain info to make the calculations are missing.. for instance I have the following:
MOTOR:
540-M4 REEDY 7.5T
Cells: 1-2S LiPoDiameter (mm): 35.9
Length (mm): 50.3
Shaft Diameter (mm): 3.15
Weight (g): 160-170
There is no information on the KV value or the Voltage of the motor so how do I figure out the esc to use or if the battery is safe?? the battery I order is:ORION
Charge Rate: 5C
Chemistry: LiPo
Capacity: 5000 mAh
Voltage: 7.4V
C-Rates: 110C
Connector: Gold Tubes 4mm
Balancer: Tubes
Length: 94mm
Width: 45mm
Height: 22mm
Weight: 217g
Hope someone who knows what they are doing can help with this so I don't ruin my electronics.. lol
MOTOR:
540-M4 REEDY 7.5T
Length (mm): 50.3
Weight (g): 160-170
Charge Rate: 5C
Chemistry: LiPo
Capacity: 5000 mAh
Voltage: 7.4V
C-Rates: 110C
Balancer: Tubes
Length: 94mm
Width: 45mm
Height: 22mm
Weight: 217g
what is my motor kv value or what is my motor watts for a reedy 540-m4 is the 540 the watts?
Ok it clearly tells you its a 2cell motor or 1 cell.. So we will go with 2 cells. thats 8.4v full charge. wont stay that high long.. motor kv is not listed correct you can guess go with others as a comparison(I think best so 6100+).more like 6500 kv . so 52,000 rpm ..now you need to power motor with a esc. Id like to see 100 amps or more(me I go the highest I can afford. servo)what this going in?) that will determine how much Torque 1 wants or needs.Gotta power servo at peak times holding a line in a 180 switch back with rollers at end of turn.so if it says it will draw 3.2 amp it can draw wat more close to 7..so I run a Ubec(20amp) always (after I remove center rx plug wire from esc).
Thank you Backyard RC... but the motor I bought doesn't say the KV value on the motor, or in the spec sheet ... nowhere to be found... so im having trouble figuring out how to do my setup... no kv no rpm ... maybe im missing it somewhere?
Voltage input: 2S LiPo
On resistance (mOhm): 0.105
Continuous current (A): 150
Dimensions (mm): 38.5 x 36.9 x 19.5
Weight w/o wires and fan (g): 44
Motor limit: 3.5T
BEC: 6.0-7.4V/5A
Fan: Optional
I used 6100 as what I could find with the lowest 7.5T I could find...
7.4v is the average voltage of a 2s lipo. All rechargeable batteries are listed like that.
An ESC max amp rating is just that, the max not what it'll pull out of the battery all the time. Most modern esc's have a built in BEC thats fine for two servos typically used in 1/10 cars and is more powerful than older stuff.
Quality motors like the Reedy m4 or similar are only rated in turns as you can change the KV and characteristics of the motor a lot with timing and rotor changes.
What are you putting all these parts in? It'd make it a lot easier for specific recomendations
if you are concerned about exact # then you have your motor dynode y a known company or you get a motor analyzer that will give you all the Numbers you need..Ive purchased up to 5 motors all the same make model and had a wide variance in kv from 1875 to 2300 at about 15 degrees timing...take same motor 5 years later they fall way behind in kv
a 7.4 volt lipo is for users to know its a 2 cell lipo and will have a max voltage of 8.4 and lvc should be at 7.80 volts I run mine to 7.60 no issue.. a High voltage lipo will be A 7.6v 8.65 max voltage a A123 cell is 3.6volts max but can be abused a lot more Have many 12 + years sit there then use n they are great...then the Lion not applicable.
