Go Back  R/C Tech Forums > General Forums > Rookie Zone
Must have on road tools? >
Old 10-26-2019 | 06:50 AM
Half_Ghost's Avatar
R/C Tech Elite Member
Questions?? Must have on road tools?
What are the must have on road tools setup wise for on road? Besides your typical camber / ride height gauges (already have from 2wd stock buggy racing). Just got my first Touring Car kit and looking to be prepared before assembling it, although i could be over thinking it haha. I will running on black carpet indoor tracks.
Half_Ghost is offline
Old 10-28-2019 | 09:00 AM
TheRulesLawyer's Avatar
Do you have calipers? You'll really need them to get assembled with any precision. Most of the stock setups just tell you to make turnbuckles X mm.
For setup-
You didn't say you have a droop gauge. Camber and ride height may or may not work across cars, depending on which you have. There is more stuff depending on how serious/repeatable you need to be.
TheRulesLawyer is offline
Old 10-29-2019 | 05:58 AM
Half_Ghost's Avatar
For setup-
I do have a caliper i plan on using during assembly / setup. My camber / ride height tools should work for on road, but i do not have and droop gauges or blocks.. Any recommendations? Thank you for the info!
Old 10-29-2019 | 06:10 AM
1/8 IC Fan's Avatar
Nowadays, even the stuff from Hobbyking / Trackstar and such is just fine for starting out. No need to go overboard. There are also many deals to be had here on Rctech. Same goes for setup wheels and such.
1/8 IC Fan is offline
Old 10-29-2019 | 10:22 AM
BLR346's Avatar
For droop you can even get away with no blocks and just buy a ride height gauge that starts as low as 1mm
Arrowmax/yokomo and other brands make a nice double sided gauge in .1mm increments
BLR346 is offline
