Go Back  R/C Tech Forums > General Forums > Rookie Zone
E Revo 2.0 Diff Problem >
Old 07-10-2018 | 08:30 AM
Default E Revo 2.0 Diff Problem
I broke two teeth off of the front diff ring gear while I attempted to use the self-righting feature. I got the ring gear replaced no problem and I added some 50k oil cuz there wasn’t much in the diff. Now when I put the diff back in it is very tight. It is not smooth like the rear diff. If I loosen the screws to the ring gear it helps a little but the movement is still kinda choppy like I can feel the gears moving. Besides adding some oil and replacing the ring gear I haven’t done anything to it. Any ideas on how to fix this?
reallyfatkitty is offline
Old 07-10-2018 | 11:33 AM
R/C Tech Elite Member
check the front pinion it could be slightly fubared
freaksofnature is offline
Old 07-10-2018 | 01:37 PM
I checked the pinion thoroughly and everything is okay. I noticed the diff was stiff even when it was completely removed from the car. I thought something was wrong with the spider gears but nothing looks wrong.
Old 07-10-2018 | 01:39 PM
Try maybe 20k or 30k in the diff it could be you have to heavy of a oil in the diff
Old 07-10-2018 | 04:40 PM
I completely drained the diff and it’s still stiff. When I put the 4 screws in the diff tightly the diff won’t even turn. When I loosen them a bit the diff loosens up a little. Only thing I can of is the spider gears but they seem fine. I’m puzzled.
Old 07-10-2018 | 04:53 PM
No clue only thing I can say is take it all the way apart and try to reassemble it and see what happens
Old 07-11-2018 | 08:34 AM
Problem solved. I took the diff apart and when putting it back together I noticed one of the o-rings wasn’t sealing correctly. Took it out and the diff works fine. I run my Mugen buggy without o-rings and was wondering if it would be okay to run the E-Revo without one too?
Old 07-11-2018 | 08:36 AM
don't know. Not familiar with the erevo diffs
Old 07-11-2018 | 10:19 AM
the rc guy's Avatar
if you remove O rings in revo2 you wont keep oil in diff.did you try a new O ring?
the rc guy is offline
Old 07-11-2018 | 01:44 PM
I don’t have an extra one on hand. I put it back in the car without the o ring and drove it for a few minutes and then checked for leaks. Didn’t see any leaks at all. I’m gonna take the diff back out and tighten everything back up and get a further inspection.
Old 07-12-2018 | 04:47 PM
Took the diff out and everything is in ship shape. Only problem is a half shaft in the front is completely destroyed. Could this have something to do with the diff?
