Motor Recommendations for Cable Cam
I am looking into building a remote control cable cam with a gimbal for a live shoot. As an individual who has never worked with RC cars, planes, etc, before I would appreciate some recommendations for a motor. The gimbal I want to use is DJI's Ronin MX. As I see it, the motor would have to follow the following requirements:
I would like the cable cam to move around a minimum speed of .015 meters/ second to a maximum speed of 3 meters/ second. That would mean that the motor would have to vary in revolutions throughout that range. If anybody has any recommendations or advice please include the following:
- Silent Operation at low and high speeds. This is a church environment so anything above a CPU fan level noise would be unacceptable.
- Smooth slow operation for smooth panning motion
- Forward, brake, reversible
- Last at least 3 hours under light use. (Note: the motor will not be in motion for the whole 3 hours, maybe only 30 min of use time)
- Take a payload of at least 7kg (This is a bit of an exaggeration and the motor isn't actually supporting all that weight, it is only moving it along a cable)
- Recommended motor with corresponding ESC
- Advice to reduce noise output from a motor
- Advice to get precise and slow controls from a motor
