Serpent S411 Hop Ups Just Arrived
Serpent Body 190mm Lex-IS Semi Painted for 1:10 RC Car #401571
For:Serpent S411 1/10th 190mm / Serpent S411 190mm Sport / Serpent 411 Limited Edition 2011 / Serpent S411 FF 1/10 EP 2wd / Serpent S411 190mm Team Edition
Item no.: 401571
Serpent Bumper Upper / Lower for Serpent S411 #401361
For: Serpent S411 1/10th 190mm / Serpent S411 190mm Team Edition
Item no.: 401361
Serpent C-Hub 4 Left + Right Hard for Serpent S411 #401455
For: Serpent S411 1/10th 190mm / Serpent S411 FF 1/10 EP 2wd / Serpent S411 190mm Team Edition
Item no.: 401455
Item no.: 401571
Item no.: 401361
Item no.: 401455
Serpent Pully Middle 19T + Spacer (3) for Serpent S411 #401360
Item no.: 401360
Serpent Pully Solid Axle 38T for Serpent S411 #401359
For: Serpent S411 1/10th 190mm / Serpent S411 190mm Sport / Serpent S411 190mm Team Edition
Item no.: 401359
Serpent Upright Hard (2) for Serpent S411 #401454
Item no.: 401454
Serpent Wishbone Front Lightweight Hard (2) For Serpent S411 #401452
Item no.: 401452
Serpent Wishbone Rear Lightweight Hard (2) for Serpent S411 #401453
[img][/img]
Item no.: 401453
Serpent Aluminum Pully 19T for Serpent S411 #401427
For:Serpent S411 1/10th 190mm / Serpent S411 190mm Team Edition
Item no.: 401427
Item no.: 401360
Item no.: 401359
Item no.: 401454
Item no.: 401452
[img][/img]
Item no.: 401453
Item no.: 401427
Serpent Pivot Ball 5mm (10) for Serpent S411 #401024
For: Serpent S400 1/10th 190mm, S411 1/10th 190mm, S411 190mm Team Edition
Item no.: 401024
Serpent Blade (16) For S411 for Serpent S411 #401409
This is a replacement Serpent Driveshaft Blade Set, and is intended for use with the Serpent S411 1/10 touring car.
For: Serpent S411 1/10th 190mm, S411 190mm Team Edition
Item no.: 401409
Serpent Pivotball Uni 4.5mm for Serpent S411 #411253
For: Serpent S411 1/10th 190mm, S411 190mm Team Edition, S120 1/12th scale, S120 Link 1/12 pancar EP, S120 Link-Tube 1/12 pancar EP, S100 Link 1/10 pancar EP, S100 LT 1/10 pancar EP
Item no.: 411253
Serpent Belt Kevlar 30S3M186 Low Friction for Serpent S411 #401353
Item no.: 401353
Serpent Belt Kevlar 30S3M510 Low Friction for Serpent S411 #401351
Item no.: 401351
Item no.: 401024
Item no.: 401409
Item no.: 411253
Item no.: 401353
Item no.: 401351
