which prop makes a 3 channel heli move foward???
this is my heli below picture, does the rear prop move my heli foward? it seems to be because i have a 3 channel heli the rear prop moves when i move the right stick foward so since this is a 9101 29 inch double horse people have told me to heat the rear prop and change the pitch to be more agressive, which i did but i dont really see the heli going any faster foward?? should i change the pitch so the blades are flat? but mainly i am asking which prop moves a 3 channel heli foward, details please and which way do i change the pitch on the rear prop( if thats the prop thats moves it foward) thanks all
Mods for the tail on your heli are the same as for the 9053 Volitation. A tail rotor with a wider surface area will generally do it. Changing the pitch won't really help much. You can find several videos on youtube and info on forums all over the net on how to go about it.
