Go Back  R/C Tech Forums > General Forums > RC Boating
Need answer before bidding ends >
Old 02-21-2013 | 05:56 AM
ryanster1999's Avatar
Default Need answer before bidding ends
I need to know if this will move my deep v 20 set up for an outboard pretty good
http://item.mobileweb.ebay.com/viewi...id=97489456786
It's a k&b 3.5cc ss outboard
ryanster1999 is offline
Old 03-21-2013 | 07:42 PM
Ron Olson's Avatar
OK, I realize that this posting is a month old but I hope that you didn't buy it. First, the price is very close to new cost and nobody should have to pay that much for a used engine. I had an SS and it was a pile of junk. I found out that the issue on mine later on was that the bottom-end con-rod bushing was missing from the factory! Mine was made just before K&B was sold to MECOA.
Can it work on a mono? That's a good question. My guess is that you have a Dumas Deep-Vee 20 by your description. Outboards generally don't do well on mono's, kind of the opposite of what you'd think seeing how there are so many full-sized outboard boats on the water. The center of gravity is a real pain in the rear as everything has to be moved foward to get it right.
OK, the updated part. I went in and looked at the engine again, it doesn't have the original stock Gold carb but the Red one. The Red carb is for .45's, not a .21. They're a hassle to set on a .21 as the fuel and air can't atomize correctly.
Ron Olson is offline
