battery Q for old nitro starter box
Hey all,
I have an older Team Associated Factory Team starter box for my RC10GT2 and I was rebuilding the car and the old 12v gel cell battery i used to use is too old and "dead".
I was looking into battery options and could get another gel cell battery, or could get a lipo or life battery. My question is, If I go 4S Lipo would that higher voltage hurt the motor? I believe when a 4S Lipo is fully charged the voltage is 16.8v and the motor wants 12v - is that OK? The starter box was designed for 12v gel cell or NiMH batteries.
Thanks!
Thanks!
Wouldn't a 3s be better in this case? a 3s has voltages closer to what the starter box is looking for. If not, you could always go with a riding lawn mower battery, they are some what cheap, and very easy to find.
I was thinking of 3s, but would that be lacking juice? Fully charged the voltage would be 4.20x3=12.6v and at storage would be 11.4v. I guess that sounds doable. They have a Hobbico Torqmaster 12v gel cell for $25 at Tower hobbies, the only problem i see with it is weight and it contains lead (it's sealed, but for disposal when that time comes).
A 3s should be fine. What your really worried about is voltage under load, a lipo will have more usable energy and voltage under load.
I've linked a very long winded article about using lipo vs AGM (gel cell) in marine applications. It maybe more information than needed, but still interesting. https://www.victronenergy.com/blog/2...um-ion-vs-agm/
Another thing with the lipo batteries, you will need to pick up a small voltage reader that plugs into the balance port. That way you can check to make sure your not going below cutoff voltage. I have linked one below that will buzz at cutoff voltage.
https://www.amazon.com/Femitu-Batter...QV2P2YSJ1JMBW5
I use a Y harness and 2 -2cell lipos. Have been for 4 years on the same box. No issues so far. Since its under load 99% of the time, free wheeling speed is not an issue. Also, at a higher voltage, the current draw goes down so it runs cooler. And considering it runs for seconds at a time are all reasons its lasted. That said, I wouldnt even consider higher than this...
Also, are you using a parallel or series Y harness?
Been working with electric motors for 30+ years so I have picked up a few things. It has the original motor ( HUGE single motor) Older true start Ofna. Also doing it in an Associated box. Using a series Y harness.
https://www.amainhobbies.com/team-as...-asc1750/p7964
this box? I have two I run 4s through with no problems besides occasional glazing of the contact plunger
Do these starter boxes use something different than a brushed motor? I always figured they used a old school style brushed motor.
