Stupid Question??
OK was wondering on a Mamba Monster ESC which way the wires go?
Is it 1.) black/red,white,red/black? Or 2.) Black/red, red/black, white? Or 3.) White, red/black, black/red? Because I've always ran it the 1st. Been searching online for the answers but all I come up with is the wires can go any which way. But I switched to the 2nd & 3rd way depending on motor running in reverse and the ESC and motor ran hotter than the 1st way. Maybe people here can have the answers. Thanks |
The motor should not run any hotter regardless of the order unless you have a bad solder connection on one of the wires.
On sensorless motors, the wire orientation does not matter. Plug it in how ever it works best for your chassis. I typically run 2 or 3 because it better matches the order of the wires coming out of the motor.
OK thanks for the insight on the matter
| All times are GMT -7. It is currently 11:37 AM. |
