Hot motor problem
Having a problem with my motor. I had it on the car stand, no wheels just recalibrating my Radio and esc. When I gave it full throttle 3-4 times for approximately 2-3 seconds, the motor would lose 70% or so power with the trigger at full throttle, and the motor got very hot and even a slight bit of smoke.
Is the motor toast? What caused it to heat up so fast just bench testing it?
Running a brushless motor unloaded will make it heat up very quickly, never give a brushless motor full throttle on a car stand/bench/etc. for more than half a second. If you got any smoke at all, it got too hot. Sometimes the rotors will detonate doing that but in your case, it sounds like you got it hot enough to start to burn some of the sator. It will probably still run, it will probably not be as fast as it was.
I can't tell you how many times we have guys send us an e-mail saying that a motor is overheating before it is even installed. We've seen this ourselves many times, if you run a motor without being connected to anything then the heat builds up really, really fast even though there is obviously much less current flowing through it. We have seen magnets come off of non-Kevlar wrapped rotors as well from too much RPM, it is never a good idea to run a motor full throttle without a load on it.
Thanks for the replies!
3Likes
