-   -   SMC RF120 not recognizing brake when setting endpoints (https://www.rctech.net/forum/radio-electronics/991262-smc-rf120-not-recognizing-brake-when-setting-endpoints.html)
Notbrick 06-29-2017 08:37 PM
SMC RF120 not recognizing brake when setting endpoints. Initial Setup
Hello everyone, After two years I am finally getting back into this RC hobby.
I am struggling to get my SMC RF120 ESC to connect to my Spektrum DX3.0 with Spektrum RX3000 receiver. I believe I have reset all radio settings to default.
Neutral Endpoint is recognized. Throttle Endpoint is recognized. But struggling with the Brake Endpoint. I then switch the Throttle to reverse on radio, and ESC did not recognize Forward when setting endpoints. I cannot figure out if its on my radio end or ESC that I am missing.
I could use some help with anyone who might be using a similar setup or experience.
Thank you.
Notbrick 07-05-2017 12:24 PM
Follow-up:
It appears that the brake trim was set at 65% from the old settings on a nitro vehicle. Now I need to step back into the stone age, charge my Ni-MH battery, and get some more testing done. I need to step into the LiPo scene asap.
