Like Tree2Likes
Zero timing esc's
Old 05-22-2017 | 04:09 AM
  #16
Originally Posted by Skiddins
Not even the Hobbywing Justock?
The JustStock meets the first three. It will run without a booster on 1 cell but some radio systems need more than 3.7v to operate plus the servo is slowed and weakened due to low voltage.
old_dude is offline
Old 05-22-2017 | 04:14 AM
  #17
Originally Posted by TOM MAR
The hobbywing in the link is also very very small. There is also a multi cell version.
The only products from HW that can not have timing programmed in are the JustStock and XR10 JustStock. The Stock Spec (both versions) can be programmed with timing.
old_dude is offline
Old 05-22-2017 | 04:20 AM
  #18
howardcano's Avatar
Originally Posted by old_dude
Thanks Howard:
I wanted to compile a list for a specific class. The general idea was I could specify a single model but that can bite you when it is no longer available. So having options was what I wanted and all I want tech to do is identify the esc and not have to know what pattern or color of lights or sequence.
So now the first three are all I need. I will go down the ROAR list again, then check each manufacturer's manual for any indication of a timing method or mode.
Fixed timing is getting pretty rare! Since I have all the data here, I just did a quick scan and came up with the following for 2s operation:
HobbyWing Justock XR10
Reedy Blackbox 800Z
Tekin RS Gen2 Spec
Turnigy Trackstar 60A Sportsman
howardcano is offline
Old 05-22-2017 | 05:42 AM
  #19
Reedy Blackbox 800Z
I think there are some older ones (maybe out of production). But you are right they are rare.
old_dude is offline
Old 05-22-2017 | 05:43 AM
  #20
theproffesor's Avatar
You left out the Tekin RS spec.
It has no timing adjustment.
theproffesor is offline
Old 05-22-2017 | 06:25 AM
  #21
howardcano's Avatar
Thanks! I updated my previous posting.
Old 05-22-2017 | 07:23 AM
  #22
TOM MAR's Avatar
TOM MAR is offline
Old 05-22-2017 | 08:22 AM
  #23
howardcano's Avatar
Incorrect! There is actually 4 2 can be programmed, 2 cannot.
You can program several things on the esc. I have 2 of them You Can NOT adjust timing in it.
From the page.
1S Zero timing
World's smallest & compact ESC.
'23.5 g'
The XR10 Stock Spec 1s has a non-timing profile preset. Timing is locked at zero in this profile. Timing can be added by changing to a different profile. All of this is within the existing software.
Old 05-22-2017 | 08:37 AM
  #24
TOM MAR's Avatar
Thanks howardcano
TOM MAR is offline
Old 05-22-2017 | 08:48 AM
  #25
Thanks howardcano
That is what i found when i read the manual on the XR10 Stock Spec's. They have a locked mode (as do several others). But take it out of that mode and timing can be programmed.
old_dude is offline
Old 05-22-2017 | 08:58 AM
  #26
TOM MAR's Avatar
I guess I need to check closed in tech. I had no idea.
TOM MAR is offline
Old 05-22-2017 | 11:02 AM
  #27
howardcano's Avatar
As long as you see the red LED at 0.25 seconds/flash, it's in zero timing regardless of the profile.
TOM MAR likes this.
Old 05-22-2017 | 02:35 PM
  #28
Reedy Blackbox 800Z
Tekin RS Gen2 Spec
Howard: According to the manual on the Tekin RS Gen2 Spec, it has available timing profiles.
old_dude is offline
Old 05-22-2017 | 02:42 PM
  #29
yzracer758's Avatar
Team Tekin
Tekin RS Spec has no timing profile options. The RS Gen 2 does have Blinky and optional timing profiles.
yzracer758 is offline
Old 05-22-2017 | 02:54 PM
  #30
howardcano's Avatar
The Tekin product page states that the Spec is always in non-timing mode, as stated by yzracer758. But the link to the manual is for the regular GenII, which does have adjustable timing. I don't know if the link is incorrect, or that there simply is no separate manual for the Spec version.
