Futaba R304SB won't link with 3PV?
So I've tried to scour the net and all the answers found proved pointless. Here's the situation;
I run a Futaba 3PV and for Channel 1 I run my Xray XB4 whereas Channel 2 runs my Traxxas Slash. I decided to build a new Team Associated B6 and I had everything except a receiver. Figured since I don't use the Slash much, I'd take the Futaba R304SB out of it and put it into my new B6. Fired up the B6 in an attempt to connect my receiver to my transmitter and it won't link. I've tried a variety of methods such as; Channel 3 on my transmitter, and tried all different servo types in my radio's menu, and attempted to link to no avail. Back to Channel 2 on my transmitter (where the Slash was connected) and attempted to link to no avail. I swapped out my lipo battery in my RC to a freshly charged one and also swapped out the batteries in my transmitter. The only thing I haven't done so far is program my ESC but I don't think that would prevent my receiver from linking to my transmitter? I also haven't swapped the receiver back into the Slash since I yanked it out, but I can say the receiver is no more than 1 month old and it has never seen water or dirt. The receiver also worked days ago in the Slash so I doubt the receiver is bad. I'm sure I'm doing something wrong but can't figure it out :flaming: |
only thing I can suggest is make sure the speed control wire plugged into the receiver the right way.
We you power on the receiver power light comes on? I have 4 of the 304sb , only difficulty I had was when she failed to power up and it turned out to be that it was fried.
Did you set the receiver to the right protocol ?
+1 on the protocol. Not sure if Futaba works similar to Sanwa but when I bind a new receiver, I have to make sure the radio protocol is set appropriately in my radio. For me it's FH4, FH3, FH2 etc. For you it'd be S-FHSS, T-FHSS and FHSS. And for that receiver I believe you need to be in T-FHSS mode.
Originally Posted by EbbTide
(Post 14901660)
I think I had a similar problem recently. I had a R304SB already bound to my 4PX, & after a ESC/motor change it wouldn't work, no led. I thought the ESC was bad, I was wrong. I had a BN R204GF-E so I switched protocol & everything is fine. I still don't know if the R304SB is any good. I know my post isn't any help, but I'm curious as to what your issue maybe. I would check what above posts state, power & protocol.
Originally Posted by anthonyscardina
(Post 14901587)
I switched it (ensuring the center plug is in the center) and no changes.
Originally Posted by Oldbutlearning
(Post 14901589)
Pressing SW does enable the LED to turn on and stay on in RED for awhile as if it's attempting to bind to my transmitter. All signs point to the receiver working as it should.
Originally Posted by Roelof
(Post 14901609)
(Post 14901660)
Originally Posted by Thrifty
(Post 14901670)
Yup. What he said.
This receiver has been bound before to my transmitter when it was in a different vehicle.
Originally Posted by Mopar2Ya
(Post 14901721)
I was hoping to be as thorough as possible in my OP but I guess not. The receiver has been bound to my 3PV before; only thing different now is I have it connected to a new ESC (that turns on just fine) and new motor. |
I need help too. Been trying to connect for a while now, no luck. What is switching the protocol? Seems to be a problem. Directions are very fuzzy.
Originally Posted by RsA89
(Post 14902500)
If we find a solution, I'll report back. |
(Post 14902500)
Got it connected. Have to make sure the wires are plugged in the right direction. Getting the hang of the controller. Confusing at first but starting to make sense.
(Post 14903053)
Originally Posted by Andy Koback
(Post 14903072)
You stated in post #8 that everything was correct. :confused:
I was very thorough in stating everything I've already done. The suggestions that followed afterward were things I've already tried. |
Originally Posted by kwikvette
(Post 14903177)
You're confusing me for the OP.
