Castle X series BEC
Old 04-11-2017 | 06:53 AM
Default Castle X series BEC
the castle X series of esc have BEC voltage adjustment of 5.5, 6, 7.5 and 8v.
and I've read in other forums that the 7.5v option is actually close to 7.25v.
my question is will a 7.4v servo work with the 7.5v option on the esc?
thanks
Eryx is offline
Old 04-28-2017 | 01:05 PM
Joe Ford's Avatar
Short answer, yes. It will work. Long answer, the way servos have historically been rated is by the nominal voltage of the battery they can be used with. So 4.8/6v means it can be used with a 4 or 5 cell NiMH battery (1.2v/cell). For a 7.4v servo that means you can operate the servo off a 2s lipo (3.7v/cell, 7.4v nominal, but 8.4v fully charged). Hope this helps.
Joe Ford is offline
Old 04-30-2017 | 05:26 AM
thank you sir
Eryx is offline
