Storage voltage for 2s Lipo >
Old 03-09-2017 | 08:45 AM
Default Storage voltage for 2s Lipo
What's the storage voltage for a 2s Lipo? My iCharger has a storage function & it stops at 7.20
Is that correct?
Thanks!
Miko1976 is offline
Old 03-09-2017 | 09:05 AM
Mine is 3.8-3.85 per cell. So 7.6 together.
Zinergy is offline
Old 03-09-2017 | 01:31 PM
Is that correct?
Thanks!
Mine also is 7.6. I'd there a setting you can change to up it to 7.6?
phinsfan76 is offline
Old 03-09-2017 | 02:08 PM
EbbTide's Avatar
7.2v is okay too. Just make sure you cycle them once in a while.
EbbTide is offline
Old 03-09-2017 | 04:12 PM
Anywhere between 3.78-3.85v/cell is considered a 'proper' storage voltage. 7.2 I would consider too low, I wouldn't even run any of my packs that low.
Xpress.. is offline
Old 03-09-2017 | 05:09 PM
rustyus's Avatar
Is that correct?
Thanks!
Which iCharger? I believe most, if not all, have a default storage charge setting of 3.85v/cell.
rustyus is offline
Old 03-10-2017 | 04:56 AM
It's the 306b. Just checked and it stores the battery at 7.76, total cell count.
Does the IR change from a stored battery to when the battery is charged? At storage the IR is 6. When fully charged it's 3.
Miko1976 is offline
Old 03-10-2017 | 05:48 AM
It's the 306b. Just checked mand it stores the battery at 7.76, total cell count.
The IR of my battery is 8. Is that good for a 2s?
Just getting into the iCharger game so trying to learn what I can.
Thanks all
Miko1976 is offline
Old 03-10-2017 | 06:59 AM
the rc guy's Avatar
ir will vary depends on what unit you check it with 8 mohms is not all that bad.. storage voltage is from 7.65v to 7.85.. i stick with 7.65 i have found better battery life with this i have some 8 year old lipos still run like the day after i got them.. i still break in charge and discharge all my Lixx batteries.. start with a 2 amp discharge go to 30 or more ..jump discharge up 5 amps each cycle.
the rc guy is offline
