LIHV batteries.
Could somebody explain, please:
Since IFMAR just allowed using LIHV but with charged until 8.4V. If LIHV still is overwhelming LIPO, just same or even worse. Best regards |
Originally Posted by mac853
(Post 14856792)
I mean, if LIHV has any advantage in the performance since charge the same voltage as LIPO.
I even saw TRION and Muchmore has released also LIHV batteries. |
I have the Protek 8500mAh 100c batteries and I can't really notice any additional power from .2VDC on my 4wd SCT. Now, Before I struggle to get 10 minute runs and last time at the track I can easily run 14 minutes with it charged at 8.60. Note that if you charge at 8.4 not just the voltage but the capacity goes down as well. i.e. mines are 8500mAh @ 8.60V but they are 7600mAh @ 8.4V.
P.S. The tracks I run. no one cares about LiHv batteries and even people run 3s on their trucks. I still lap them on 2s tho. 3S SCT is not faster but longer run time which I now can achieve with my LiHv batteries. |
Originally Posted by JRSlash
(Post 14857154)
P.S. The tracks I run. no one cares about LiHv batteries and even people run 3s on their trucks. I still lap them on 2s tho. 3S SCT is not faster but longer run time which I now can achieve with my LiHv batteries. From 8.6 down to 8.4 would really affect battery capacity and car run. Thanks! |
(Post 14857154)
(Post 14856792)
It would interesting to see someone do a back to back track test with a standard lipo vs a HV lipo.Or even a discharge voltage test. If anyone knows of this being done point me to the thread.
Originally Posted by sleddriver
(Post 14865571)
I'm assuming you mean not faster around the track because they can't control the power. 3S in the same KV/turn motor will be way faster than 2S unless you get a lower KV motor to give similar RPM.
Originally Posted by skrib21
(Post 14868224)
I have done a few tests both with 1s and 2s batteries, I was very disappointed with the hv lipo. The hvac liposuction only showed more voltage for the first 15 seconds, then the voltage stayed the same as the regular lipo. |
If charging to 8.4V, won't be much of a difference, even under high amp charging.
What will make a bigger difference is the IR of the battery, regardless whether it is LiHV or not. I had a LiHV that performed worse than my regular packs, because the IR was higher. Quality of cells > LiHV |
(Post 14868224)
| All times are GMT -7. It is currently 10:30 AM. |
