Transponder advice
Old 02-26-2017 | 10:45 AM
Default Transponder advice
What is the difference between an RC4 3 wire transponder and RC4 Hybrid 2 wire transponder? Is the Hybrid worth an additional 30 bucks? do they both work with the available phone app? Sorry if this has been posted somewhere else. I searched for a while but nothing popped up unless it was in the middle of a larger post with a different topic.
Thanks DC!
crowebar is offline
Old 02-26-2017 | 10:58 AM
the hybrid works on all systems(old and new). the 3 wire only works on the latest system.
if you don't plan on traveling and know the track you run at uses a system it works with then get the cheaper 3 wire.
the app thing is a waste of time. it's dependent on if your local track is uploading the results to the site. I don't think I've ever seen one uploaded even big national events. it's not transponder dependent.
http://www.mylaps.com/data/sitemanag...patibility.png
burnnitro is offline
Old 02-26-2017 | 01:08 PM
Perfect! That is exactly what I needed to know!
crowebar is offline
