-   -   viper esc calibration (https://www.rctech.net/forum/radio-electronics/978679-viper-esc-calibration.html)
Slap 02-17-2017 07:02 PM
I have a viper vtx10 I bought from a member here a few months ago and had never used it , so I go to try to put it in my car and wen I turn the esc on it just keeps beeping wont got to calibration mode like the instruction say by holding the button , any ideas? or do I just have a paperweight
EbbTide 02-17-2017 07:10 PM
It's possible you'll need to rebind the receiver. Or check that your throttle trim is set to neutral
Slap 02-17-2017 07:15 PM
I checked trim its at neutral and tried rebinding steering works but that's it
EbbTide 02-17-2017 07:26 PM
I'd try looking at the manual but I can't find it online. Does yours have any diagnostic tips like beep codes?
Otherwise maybe you could try hooking it up to a program card if you have/can find one and update it's firmware, but it may be a bit difficult to find the updates.
I'd also try resoldering as a last resort.
you can try posting in this thread below. It's been inactive for a while but someone might have a better answer there too.
http://www.rctech.net/forum/radio-el...er-rc-804.html
nodrog 02-17-2017 07:58 PM
programming guide
instruction sheet
not sure if you have these but I'll post em up anyways, good luck
Jamie James 02-17-2017 08:13 PM
Try very lightly moving the trigger forward and back. It sounds like the ESC can't find neutral.
Slap 02-17-2017 08:31 PM
Originally Posted by nodrog (Post 14841769)
programming guide
instruction sheet
thanks I got it now , I wasn't pressing the button quick enough after startup lol
