-   -   Installing a switch for gyro. (https://www.rctech.net/forum/radio-electronics/977859-installing-switch-gyro.html)
JB1004 02-11-2017 03:30 AM
Hello,
I am planning on installing a gyro on my Stampede xl5.
I am thinking of connecting 3PDT on-on toggle switch between receiver, gyro and servo.
But I am not quite sure if this will work to turn gyro on and off.
I have drawn a schematic for it.
dropbox.com/s/jajcqi4qh6skzaa/2017-02-11%2022.22.18.jpg?dl=0
Can anyone tell me if it will work or if not, what should I do to make it work?
Thank you
mikeygar 02-11-2017 08:41 AM
i think the + and - are constantly powered from the receiver so not sure how you will trigger the relay.
gigaplex 02-11-2017 12:33 PM
They mentioned a 3PDT switch, which is basically a 3 pin toggle that chooses been one output or another. There's no relay. All 3 pins, signal + and -, will be switched. It should work.
The schematic drawing is a bit misleading as it only has a single line representing a 3 wire lead.
Edit: my one concern would be whether or not the gyro will safely handle having the output pins being powered when bypassed, since they're not isolated from the servo.
JB1004 02-11-2017 01:46 PM
Thank you for your reply!
I was thinking about that problem too, do you think installing three diodes(1N4148) will help?
dropbox.com/s/qtoi5xi0tti0zme/2017-02-12%2016.18.59.jpg?dl=0
Also, I got a different suggestion about turning the signal from gyro on and off. Do you think this will work better than the one above?
dropbox.com/s/msm8zmr9onr6wqa/2017-02-12%2017.10.13.jpg?dl=0
THANK YOU SO MUCH!
mikeygar 02-12-2017 07:47 PM
haha my mistake; was thinking the whole time how he would trigger this remotely... Interesting project here.
