Digital Servo vs ESC ppm control >
Old 01-29-2017 | 11:48 PM
Default Digital Servo vs ESC ppm control
Curious as to what is different between digital servos and ESCs interpretation of the ppm controls from the RX.
I ask as I have a really strange problem with my basher sabertooth, stock electronics + flysky 3 channel radio and reciever.
Turned it on a few days ago, and servo is fully dead. No centering torque, or noise.
Swapped ESC and servo channels. ESC/motor run just fine, servo still dead.
Aight it's a dead servo, except I tried 4 other servos I have lying around. The 2 digitals (d770 solar servo) fully dead, and I know at least one was working last time I ran the car it's on (6 months ago). The continuous rotation servo spun, but did not change speed with TX commands. Finally, a plastic geared horror I dug up was also fully dead.
Opened up stock servo. All looks fine inside, wires soldered, no cancer smell, no scorching...
Checked +/- voltage from ESC, 6.2V so that's all good.
Checked signal voltage with my multimeter. 0.6V, 0.4V and 0.3V for full one way, middle, full the other. Matches up to 2ms/50Hz 6V, 1.5ms, and 1ms fairly well. Don't have access to a scope right now unfortunately.
So yeah, any of you folks have any idea what could be busted? Or any insight into what is different between ESCs and servos control wise?
Frohst is offline
