Battery and servo help >
Old 01-12-2017 | 02:02 PM
Default Battery and servo help
Two quick questions.
I'm in the process of making a bait boat for fishing. To help with keeping it balanced I'd like to use two batteries. Would this be be possible as long as the voltage didn't over load the esc? I'm sure I've seen a "Y" style deans connector.
My other problem is I bought a cheapy mini Turnigy T5180MG servo which is meant to have 180 degree movement but after connecting it all up it just has the standard movement. Have I got something set up wrong or is it faulty?
Andyk is offline
Old 01-12-2017 | 02:23 PM
EbbTide's Avatar
You can run two batteries in parallel which just increases the capacity while maintaining the original voltage. I can't find a Dean's style version but this is a Traxxas parallel adapter. If you wire three Dean's plugs in the same fashion it'll work the same.
https://www.amainhobbies.com/traxxas-parallel-battery-wire-harness-traxxas-id-tra3064x/p481059
And for the servo, make sure your end points are set to their highest value
EbbTide is offline
Old 01-12-2017 | 02:45 PM
Ok thanks, just got to find some suitable batteries now.
How do I adjust the end points on the servo??
Andyk is offline
Old 01-12-2017 | 02:47 PM
EbbTide's Avatar
That's usually done through your radio. I'd check the manual for it and see if that is an option. And also make sure the steering trim is centered
EbbTide is offline
Old 01-13-2017 | 03:04 AM
Doesn't look like it is an option..... Any other ideas?
Andyk is offline
Old 01-13-2017 | 03:29 AM
What radio do you have?
Rizen is offline
Old 01-13-2017 | 06:15 AM
It's a Flysky FS-GT2B. Couldn't see anything obvious in the manual
Andyk is offline
Old 01-13-2017 | 07:12 AM
Ok, if I'm not mistaken, looking at the knobs/lights/switch panel. Directly above the power switch in the middle should be 3 knobs that are larger.
Closest to the power switch I believe should be the one, with the battery plugged in, turn on the radio and then car. Slowly turn the bottom knob a little bit, then test your steering. Rinse and repeat till your steering has the range needed/desired without the servo trying to turn past the physical limits of the car's steering mechanisms. (If it's not the bottom that does it, try the top, one should "align" the steering left/center/right, the other should reduce/increase the servo range of motion.)
Rizen is offline
Old 01-13-2017 | 11:26 AM
You're right it's the bottom knob. Turns out it's been fully turned anyway and makes no difference . I'll try messaging the seller and see if they can help. Any other bright ideas in the mean time are well received
Andyk is offline
Old 01-13-2017 | 02:32 PM
Usually if it's turned fully counter clockwise it's "wide open" further clockwise it's turned the narrower the degree the servo turns.
Rizen is offline
Old 01-13-2017 | 02:43 PM
EbbTide's Avatar
Is it possible that the servo needs to be programmed to run 180 degrees? I know for hitec servos they have a program box to make it happen but I couldn't find anything specifically for turnigy servos
EbbTide is offline
Old 01-14-2017 | 10:46 AM
I would of thought if it was being sold as a servo with 180 degree movement it would do it out the box. I've emailed the seller, just waiting on a response. Will do a google search in the meantime.
Thanks for your help guys
Andyk is offline
Old 01-14-2017 | 11:01 AM
EbbTide's Avatar
Update the thread if you find the answer so anyone looking for it in the future can benefit too Hopefully it was just a bad first servo and they'll send a replacement
EbbTide is offline
Old 01-15-2017 | 11:11 AM
Haven't really found the answer. My local shop is closed Sundays and the seller I got it from has only suggested what you guys have said so I've asked for a replacement. Hopefully that solves it!
Andyk is offline
Old 01-15-2017 | 12:28 PM
Turns out it's down to the radio. Because the radio is designed for cars it limits the servo so it doesn't try to over turn the wheels and damage the car. I've seen a lead which allows a standard servo to rotate 180 degrees so will try that.
Andyk is offline
