Steering exponential
I'm after a perfectly linear feel to the steering in my AE B6.
I've always used -ve expo on my KO Propo EX-10, normally around -15%. I'm questioning if this is enough.
What puzzles me is reading/hearing people say 'I don't use expo because I like the linear feel'.
The servos we use in cars do not provide a linear lateral output. The servo moves through an arc, mechanically the movement around centre is greater at given input than at the extremity of travel. Therefore 0% expo on a transmitter equals positive mechanical expo.
What complicates things in a buggy is it's not just the servo horn that moves in an arc, so do the crank and hubs.
Am I right in thinking if I achieve a perfectly linear lateral movement for the horn, this will effectively translate to linear movement through the rest of the system?
-46% expo seems to be spot on for the horn.
I usually run at least enough exponential curve on the steering to make up for the positive mechanical expo you describe. Do what works for you!
You could use a setup station to measure the wheel lock versus transmitter wheel motion if you truly wanted to get as close as possible to a linear response. You'll never get it perfect, of course, because there's no guarantee the transmitter curve will match all of the non-linearities created by the linkages, and then of course there's Ackerman, so which wheel should you measure?
Having in mind that 1:1 cars implicitly have mechanical steering expo and it does not seem to be a big deal, I would tend to say having 0% tx expo would be most like the steering feel in 1:1 cars. There is no such thing like 100% linear steering as far as rotating parts are involved, which is always in conventional car steering.
Buddies who have driven my cars always comment it is easy to drive and "dialed" - sometimes i can't even drive theirs it is so twitchy / sensitive.
