-   -   Power lab 6 help (https://www.rctech.net/forum/radio-electronics/972554-power-lab-6-help.html)
Caveman01 12-29-2016 12:59 PM
Power lab 6 help
So I have a cellpropower lab 6 and bought the protek RC parallel charging board to go with it and the wiring don't match up, so before I just randomly order another board what ones work with the pl6? I don't need the one from revolectrixs for $65. I'll only be charging 4 batteries at the most together.
EAMotorsports 12-29-2016 06:40 PM
You have to get the Power lab FMA balance board. It usues a JST-JP connector which is the only one that will plug into the charger.
EA
dtr 12-30-2016 12:42 PM
You can also change the connector on the balance cable of the Protek board to JST-PA.
Caveman01 01-01-2017 01:48 PM
OK I can do that just don't know where to get one. I've looked around just don't know what the right one would be. Do you have a link? Thanks.
phildoggg 01-01-2017 02:05 PM
http://www.progressiverc.com/ has all you need.
Caveman01 01-01-2017 04:35 PM
Originally Posted by phildoggg (Post 14785774)
OK thanks so I should order this one then? http://www.progressiverc.com/fma-powerlab-8-balance-cable.html. I'll be looking for a new battery too so I'll check back here soon. Thanks again for all the input.
dtr 01-02-2017 12:04 PM
Yes, that should be the right one, you'll need a jst-xh connector to plug into the balance board, it looks like a 7wire is needed. Start from the black wire.
Caveman01 01-02-2017 06:38 PM
OK thanks, when It gets here I'll try to figure it out.
