Weird ESC problem
Put a Tekin RSX in my Losi 22-4. When I put the throttle in forward the wheels spin then slowly down then start spinning again. Odd thing is that this doesn't happen in revere. Tried a new sensor wire with no luck.
What the hell? Any ideas?
Motor is Reedy 5.5
12 gauge wires
Airtronics transmitter.
Timing profile is set to blinky. No boost.
Is the ESC screwed?
Thank to everyone in advance!
Motor is Reedy 5.5
12 gauge wires
Is the ESC screwed?
Set your throttle and brake end points to 100%. Throttle/brake dual rate 100%. Make sure exponential/curve is set to 0%.
After this, calibrate your esc again. If this does not help, set throttle REVerse on your transmitter and calibrate again. Maybe this helps.
Thanks for the response. I tried all these things as suggested by my fellow track goers. Perhaps a faulty ESC?
