My M12 keeps going to brake!
So right in the middle of the race my car was going to brake. After the race when you scroll to look at the center point is shows 16% brake. Any way to zero it back to center?
VR Adjust. It's in one of the menus.
Ck all trims on TX, center all. ESC ck brake strength and Drag brake. if not, set to zero. Recalibrate you ESC. And redo your setup.
re-calibrate the VR.
I heard the neutral point will sometimes off, but it happened on the very first lot of M12.
