Do sensor boards just GO BAD?
I bought a motor on here last week with 15 min of run time on it. Super clean looking motor upon arrival.The seller said he checked it before packaging up. Being its a Novak 25.5, I wanted to check the timing and amp draw before mounting it in my F1. On the Gforce motor checker, I get no A,B or C leds lighting up when rotating the armature by hand. It will run the motor in the KV mode, but slow. It won't run the motor in the timing mode.
I believe the seller saying it worked for him, so do these boards just work then go bad? If so this would be my first.
Your experience would be helpful. Thank you.
Thanks for your reply. After running it on the KV mode, the C timing sensor lights dim. If I rotate the rotor, the light goes out and none light up. Tried a second sensor wire, the same. Tried another motor and everything worked as it should. I'll check for a bent pin on the motors sensor port.
Upon further inspection, I believe I didn't seat the sensor harness deep enough in the end bell. The rubber boot around the connector (Novak) is snug and I didn't have it fully seated. Thank you V-point!
I found with the Novak motors is to loosen the 3 sensor screws and then plug the harness in and tighten the screws back up. Same when removing the harness. Just remember to check where your timing is before you loosen the screws.
