Tekin T8 and Rx8 Stange Issue >
Old 08-18-2016 | 06:25 AM
Default Tekin T8 and Rx8 Stange Issue
Hello all I'm new back in the RC scene and I recently setup my Mbx7r Eco with a Tekin Rx8 Gen 2 and a SMC motor and it has been running good but I picked up a Tekin T8 Gen2 and I'm having a strange issue. When the motor is connected it will run for a minute then the motor seems like it just locks up. The motor will make a noise like its trying to turn but it just cant in either direction. The motor is connected correctly (A-A B-B C-C) but continues to give me problems. Does anyone have any ideas what this could be? Thanks in advanced everyone!
smejia90 is offline
Old 08-18-2016 | 02:25 PM
Randy_Pike's Avatar
Team Tekin
Have you tried running it sensorless? The Rx8 Gen2 is equipped with a sensor tester feature. If your motor has a sensor board going in and out of operation, it will do as you describe.
Also make sure you're batteries are up the load, as well as their connectors. If they lose connection or have too much resistance again this can occur.
Randy_Pike is offline
Old 08-18-2016 | 05:10 PM
Thanks Randy, I called support today and that's what they mentioned and I just ran it sensor less and it runs great without it connected.
smejia90 is offline
