Problem diagnosing
Old 08-14-2016 | 04:50 PM
Default Problem diagnosing
I am trying to figure it out why my buggy was behaving very irratic . It would have a lot of punch and power for 5 seconds then crawls for a few seconds.....then power and punch again....then crawls and buggy wouldn't clear the jumps....then power again.
I went home and cleaned the car and saw that the sensor plug into my esc was off. Would this be the culprit?
Phillip F is offline
Old 08-14-2016 | 05:07 PM
King DORK's Avatar
Let us know what car you have, radio, esc, motor, servo, and battery. All of this info will help.
King DORK is offline
Old 08-14-2016 | 05:24 PM
AE B6 buggy, Futaba 4PLS with Futaba R204GF-E receiver, HW StockSpec v3.1 esc, Fantom 17.5T, Protek 150T servo, SMC 4000mah Lipo.
Old 08-14-2016 | 06:03 PM
Geezatec's Avatar
Futaba 4pls, trims at 12 o'clock, EPA at 100%. Redo calibration on ESC as per manual. Make sure ESC confirms calibration by LED or tones.
Geezatec is offline
Old 08-14-2016 | 06:04 PM
RobsRacin's Avatar
Regional Moderator
Sensor wire could do that, I would say get that put back in and recalibrate and try again.
RobsRacin is offline
Old 08-14-2016 | 06:25 PM
Plug it back in and test it in the driveway/street etc. (watch for traffic)
Andy Koback is offline
Old 08-14-2016 | 07:34 PM
Geezatec's Avatar
Or possibly your gear ratio too high, lower your pinion to the smaller.
Geezatec is offline
Old 08-14-2016 | 09:31 PM
update.
plugged it back in. Did not even calibrate... because it drives normally.
Everything is A OK.
For some reason the sensor plug disconnected from the ESC and must have been dangling without me knowing it . I will buy a new sensor wire just to make sure. Maybe the sensor connector is just worn out.
thank you guys for the response.
