Battery Wire Gauge
Wanting to wire up my new touring car setup with 13.5t motor this weekend. After reading up on other topics etc. decided to go with 14 gauge for the motor and was just going to use the wire that came with the esc for the battery but they aren't long enough as my lipos don't have wires as they have inboard connections. Will 14 gauge be ok for 2s lipo? The wires that came with the esc are 12 gauge and the wires that came with the battery (that are on another car) are also 12 gauge.
You could probably get away with 14 but I wouldn't recommend it. If the esc/motor were to draw excessive amps it could cause problems, even melt or catch wires on fire. Again, amps are the issue here, it really depends how hard you are running your motor, timing/boost, and gearing that will alter how many amps you're drawing at a time. If its all you have and you're in a pinch you could test it and pull the car off early to feel the wire temps.
But I agree that 14AWG should be safe for the battery with a 13.5T.
Keep an eye on things until you can get proper 12awg
For a Roar Spec 13.5 the four strands in the winding (2 of 21 and 2 of 23) taken together is approximately equivalent to 16 Ga wire. So you are not going to overheat 14 Ga wire that is in the air with the current the 16 Ga wire in the motor can survive.
While I'm not disagreeing with you, 2/3 duty cycle is still the same order of magnitude. I believe we're in agreement that if current levels are enough to overcome the wire rating at the battery end, it's still going to be pushing the limits at the motor end. For that reason I wouldn't recommend using a lower rated motor wire than the battery wire.
The ratio of resistance between 12AWG and 14AWG is very close to 2/3. So if one were looking to obtain a similar temperature rise on the battery and motor wires, then 12AWG on the battery and 14AWG on the motor would do the trick.
