recommendations for waterproof esc with 6v bec and motor??
I'm looking for a 35t motor and brushed sensorless waterproof esc with drag brakes and 6v bec at least 2amp just in case (probably getting a waterproof servo with 12kg or more torque)
so far these are what I've found:
holmes hobbies is rather pricey. almost half the cost of the scx10 II i got.
sidewinder 3 seems fine but i will need to get the castle bec
eiger seems alright?
HobbyWing QuicRun 1/8 Brushless WaterProof 150A ESC WP-8BL150 USD$84.90 (maybe get it to run at brushed sensorless mode?)
Tekin FXR ESC Crawler Combo 45T motor combo USD$122.90, 35T combo is OOS
any recommendations or comments on the above choices?
To be clear, are you looking for a brushed or brushless ESC? I assume you are actually looking for a brushed crawler ESC (brushed motors are neither sensored or sensorless and brushless ESC's won't run them) in which case, this is what you want to buy: http://www.hobbywingdirect.com/produ...c-2-3s-brushed
For the motor, any 35t brushed one will work: example: https://www.amazon.com/RC4WD-Crawler.../dp/B00DZ7CXYQ
I am looking for a brushed esc
that esc only has 5v bec
