Quicrun 1060 brushed issues >
Old 06-13-2016 | 12:02 PM
Default Quicrun 1060 brushed issues
After killing a cheap motor and swapping it out the esc now has a faint beep when turned on and does not power the motor. All the led flashes during throttle position set up and when using throttle on controller flash as they should but no actual output to motor. Tried multiple 2s and 3s lipo and the motor is good. Also the led glows faint when battery is connected and switched off. Any help is appreciated
mbuilt is offline
