Servo help!!!!
Old 05-29-2016 | 04:50 AM
MeasuresMicrons's Avatar
Default Servo help!!!!
I've come to learn that my Caslte MM2 ESC & my Savox don't play well together, I get massive glitching even after the glitch buster is installed. Looking for suggestions on a servo for 1/8 BL buggy.
MeasuresMicrons is offline
Old 06-01-2016 | 05:34 PM
Look at the protek 130 & 150 servos
turbo88fox is offline
Old 06-01-2016 | 05:54 PM
Geezatec's Avatar
obviously you want the Savox Servos. Get an ESC that can handle the Savox.
What Radio system you using?
Geezatec is offline
Old 06-02-2016 | 08:24 AM
I'm running the Futaba 4PLS, I've heard that the Savox doesn't play well with the CC MM2 ESC, problem is the ECS puts out 5.5v, I think there may be an issues there. I've always had great luck with Hitec, my older 1/8 buggy ran a Hitec and MM2 with no issues. I just picked up a new Hitec servo. Thanks.
Old 06-02-2016 | 12:21 PM
Geezatec's Avatar
My thinking is the RX cant handle Servo and ESC as the combination. Savox do draw power. Me also Hitec do well just a class lower then Savox. Hitec HT/HS/MG/BB Does work with Castle products.
Geezatec is offline
