-   -   Motor Temp Problems-Tekin (https://www.rctech.net/forum/radio-electronics/939818-motor-temp-problems-tekin.html)
Bh1989 04-15-2016 09:13 AM
I am running a Tekin RX8 Gen 2 with A Tekin T8 2050 in My losi Eight E 3.0 Buggy. I am having issues with the motor temps after 10-15 mins of running. I am running the stock 43t spur gear and a 15 tooth pinion. I run a 4s Turnigy 5000 MaH battery.(50c) I run on an indoor clay track, I would say Medium in size. I have tried different pinion gears and cutting more cooling holes in the body. I have the ESC settings to default and turned all timing to 0. When I was done running 12 mins last night at practice, i couldn't even put my hand on the motor. I do not have a temp gun but when I polled the ESC data the temp was right at about 200 for the motor. I have only run this step about 5 times with all the same results. Everything was purchased brand new a month ago.
Any Ideas?
yzracer758 04-15-2016 10:01 AM
Any Ideas?
If your getting a fair amount of wheel spin, I would suggest lowering the current limiter some. Also if your using up most of the batteries voltage during your run you will generate more heat. Less voltage creates more inefficiency and more heat as a result.
Your gearing is fine so no need to mess with that.
Bh1989 04-15-2016 07:23 PM
I don't think I get a ton of wheel spin, but I could be wrong. I will try lowering the current limit and see what happens. Thank you
Jwilliams5 04-15-2016 07:45 PM
Simple solution... We run 8 min mains almost everywhere. So limit your runs to 8 min. Also in an e buggy you should really only need a 1900kv. Any more than that without a big 1/8 scale outdoor track and your asking for temp issues. My .02...
Davidka 04-15-2016 07:57 PM
Current limiter -65-80% tops
Brake - dial back until strong enough but no more.
Another thing I found to help was timing profile #2 (10* advance) and gear down 1 tooth. Lowers load off the bottom end, keeps top end on lower load. Your mileage may vary.
I was running 15 minute mains on 4500mah/4s.
Bh1989 04-15-2016 07:58 PM
I put that motor in because our outdoor track is really big. I only run indoors when the outdoor is closed. I just got the buggy running the past few weeks. We run 10 min mains in e buggy and when we run with the nitro guys, we do battery changes. So I need to control this temp issues before it gets hot outside.
Tommygun1 04-15-2016 08:40 PM
I have that same motor. Ran it in my 3.0 last year with a 13 tooth. I run on huuge outdoor tracks. I really think your overgeared.
fast-ho-cars 04-15-2016 09:29 PM
i have same TLR 1/8th e-buggy, with 1900 tekin rx8 gen 2 ESC i showed at our local 1/10 size track with 15/43 and was told i'm over geared. i was told i need to drop to 12t pinion and it was recommended that i also go to the 45T spur which i did.
rotor head33 04-15-2016 10:01 PM
I'm running 1900 with 45/15 and run 30 minutes at a time on our track and never reach 175 (mt4 temp telemetry) even during a race I don't see that kind of temp. And we are on an outdoor track in hot humid Louisiana weather.
thecman26 04-16-2016 04:41 AM
That sure is a lotta motor for buggy!
Bh1989 04-16-2016 07:44 AM
I started with a 13 tooth pinion, with the same heat problems. I have trie 13, 14, and currently have 15 with no changes in temp, Everything in the 200 degree range on the data log from esc. Motor too hot to touch.
bmag5000 04-16-2016 08:03 AM
My motor in my 8th runs 130 degrees after a 25 min run.
MX304 04-16-2016 08:12 AM
I have run a 2050 and the 1900. The 1900 is so much more efficient, it isn't even funny. I doubt you will ever control the temps with the 2050, especially when running long mains with multiple batteries. The 1900 is the perfect motor for e-buggy and you won't be slow. The 2050 is overkill by a lot.
mavdriver 04-16-2016 09:36 AM
Any Ideas?
My bud runs the same identical set up on his Losi 8ight buggy gen 2 esc 2050 motor and 15 pinion his getting 140-150 and we are running on a big outdoor track another thing i can think off check if your pinion is not to tight against the spur also if that`s not problem remove your pinion , and see if the diffs are not binding , put the buggy on the ground and roll it if it stops right away bearings could be the problem , Losi bearings are notorious for going bad i had a similar problem on my Losi 3.0 truggy the bearings on my center diff and my outer wheel bearings seize , causing heat on my motor after i fix that is now running consistant 150 - 160 also check your timing hope that helps .
SuperBoots 04-16-2016 10:30 AM
What thermometers are you guys using to measure your temps?
