How do I connect this battery?
This is the first time I've bought a battery without the cells exposed and without solder tabs on the battery end.
How do I connect leads to this type of battery pack? Do I just stick 12 or 14 gauge wires in there and solder away, or is there a connector designed to be inserted into the gold holes?
Thanks.
Thanks.
Thanks!
Does the one with the charge/balance adapter work (sorry I cannot post links because I don't have enough posts)? Do I need the 'balance connector'? Or should i just buy some wire and male bullets separately? I have Deans on my ESC so I need to go bullet to deans.
This would do what you need: http://www.amainhobbies.com/rc-cars-...-short/p453919
4mm bullets connectors. Depending what connector on your lipo battery. If you use Dean's connector get Dean's female connector w/pigtail and solder on bullets to length you decide. They have pre-made cable for your lipo charger
