-   -   lrp flow esc switch issue (https://www.rctech.net/forum/radio-electronics/914948-lrp-flow-esc-switch-issue.html)
turtle189 02-28-2016 01:49 PM
Anyone know if you can cut off power switch and solder the two wires together without issue?
Sabertooth 02-28-2016 02:27 PM
Yes you can remove switch .. Id replace with another switch
turtle189 02-28-2016 02:33 PM
Thanks.
Andy Koback 02-28-2016 04:02 PM
If you cut the switch off, plug in the battery and see if it powers up.If it doesn't, twist the two wires together and then see if it powers up. Some switches make the circuit or break the circuit. Tekins can run without wires being together. Never tried an LRP.
B16A2 02-28-2016 04:38 PM
LRP Flow turns on with the wires cut, and turns off then you connect the wires
just cut the switch off and make sure there are no wires bare to touch anything, you can shrink wrap then ends to be sure.
turtle189 02-28-2016 04:57 PM
Thanks will do.
