Charger help
1 Attachment(s)
Hi i recently was given a kyosho mad force truck and i was told it needs a charger for the car but im not sure what the person meant as its a nitro engine The bit he said the charger goes in is located by the electric box where the reciever goes and its 3 pronged with a red and black wire coming out of it
If you have any ideas as to what it is for or needs id apreciate any help Many thanks Jay |
The receiver has a battery pack that plugs into it to provide power for the servos and receiver. That's what you may have to charge. If it's not regular replaceable batteries (AA for example), it may be a small LiPo/LiFe/NiMH battery pack that will need charged.
As klaymon mentioned, the receiver and servo's require battery power to run your nitro car.
If you only have AA's, you can even use one of these brackets. Just make sure the black and red wires go into the receiver in the right polarity. http://www.amazon.com/Futaba-FBB1-Ce...ver+battery+rc For charging these smaller receiver packs, if Nicd/Nimh, I'd use a slow charger. Usually transmitter chargers have the transmitter and receiver charger receptacles. |
Thanks for the help il have a look now what batteries are in there
1 Attachment(s)
I just opened it up and it has 4 AA batteries wrapped up in plastic they are rechargable so is there a type of charger i can get for it instead of me takin it out and getting new bits and doing the wiring
Thanks Jay |
Just to check if i use that bit off amazon would i then be able to put the charging conector in the electrical box
Sorry for all the questions im very new to this and have always wanted a nitro car and dont want to mess it up even more than it already is |
| All times are GMT -7. It is currently 04:05 AM. |
