Orion Vortex R 8.1pro >
Old 01-02-2016 | 05:18 PM
Default Orion Vortex R 8.1pro
I need to reverse the motor rotation direction in sensor cable mode, so can't swap 2 of the motor wires.
I tried reversing the radio throttle and it didn't work.
I have also found nothing in the software.
harder is offline
Old 01-02-2016 | 06:12 PM
ThePanda's Avatar
these motors and escs are designed to run in a certain direction. Reversing the direction is usually not something you would do. what car is it being run in, it shoud run the wheels in the correct direction.
ThePanda is offline
Old 01-02-2016 | 07:11 PM
Kyosho MP9 tki3 with electric conversion kit and Tekin T8 gen2 motor
harder is offline
Old 01-04-2016 | 08:13 PM
Still no luck.
I wonder if Tebo had the same issue? The only difference from his car to mine is the motor.
harder is offline
