I bought one thinking it came with the ac adapter but it didnt. I used my laptop charger and it seemed to work. Just wondering if that is all it needs. Thanks!!!
Iridium87
12-26-2015 04:54 PM
Originally Posted by ben42
(Post 14320535)
Have a look at the brick of the power supply, make sure the specs match the requirements of your charger. Also make sure the centre pin is negative on both the charger and the connector from the power supply. There should be a little diagram on both.
The only issue I can see is not having enough amps to charge at a higher rate.
platgof
12-27-2015 06:01 AM
You can pick up computer power supplies off ebay, that have plenty of power and are very cheap.
iraklas
01-16-2016 02:00 PM
The amp reading on my imax often ranges from 0 to the pre set setting while charging. Is the power supply to blame?
