Maclan Racing Products Discussion
#1276
Esc question
I run dirt oval a 10.5 and a 7.5t motors was looking into these will they work for me and anyone know when they will be restocked
#1277
I just purchased the premium UHT rotor for my v2 17.5. I am currently running a 4.25 fdr on grey carpet with the stock UHT rotor. Would the fdr be the same for the premium rotor or should I be starting with a different gearing ratio?
#1279
Awesome! I just put the motor on my analyzer and at 48* timing which it's seems most people are running, Iam getting a reading of 3500 kv(!) but it's at 6.6 amps. For other motors I like to be under 5.0 amps. Is 6.6A unreasonable or a good rate for the v2?
#1284
#1285
Hey guys,
Got a problem with my ESC and/or motor. I'm using a Maclam MMAX Pico and a 13.5t MRR Team Edition Ver2 motor. They are fairly new and have been running fine for my last few races, but has now developed a problem when I use full throttle. It sort of like stutters for a bit before it launches. If I ease the throttle on it's okay. I've taken a video which will hopefully show what I'm talking about.
It doesn't do it with my other Maclan ESC and motor. I've reset this ESC, I've changed the slipper and gearing, changed the sensor cable, and the ESC reciever cable. Nothing seems to fix it. Could the capacitor module be dead and need replacing?
I have the same ESC and motor and it is doing the exact same thing. It's in a tekno eb410. I resoldered, disassembled the motor, and changed about every setting in the esc but it still does it. Don't have another sensored motor to try to see if it's the ESC, but I believe it's the sensor board in the motor. What was the fix for you problem?
#1287
#1288
Now, don't run the battery dead etc, but see if you see the issue still.
#1289
Has anyone come across this before?
I've been using my phone to change settings on the MMax pro but I've left my OTG adapter at the track. I plug in my prolink card but find when trying to access the ESC settings, it doesn't! It just goes back to the screen where I find what profile is loaded
#1290
I fixed my own problem and if the Maclan reps want to find out what happened exactly they can reach out.
