Originally Posted by EDWARD2003
(Post 14173177)
If it's for one cell applications, I would assume just dividing your values by 2.
They have to find a way to run any motor without any fuse blowing.....
Originally Posted by bertrandsv87
(Post 14173960)
nobody typically cares about mod classes - you usually have more power available than you need or, for 90% of us, can handle. The spec classes, 21.5, 17.5 are the ones where extra oomph can actually help. It is more than just finding the peak output - for me it is more about the science of matching your motor to your car and track so that it makes the most of its available power (ie: fast) as efficiently as possible (ie: not melting). |
I believe the mod class could also benefit from a similar dyno machine that could handle the amp pulls of any mod motor... There are dud motors in the mod class too... I do however understand your point of view...
(Post 14173960)
Peak current draw is over 120A. Make sure your ESC is working properly, sensor lead is connected ect. |
Where is everyone ordering their eagle dyno, I cant seem to find them anywhere other than rakuten.
Originally Posted by mtveten
(Post 14177324)
(Post 14177497)
Have done some runs on mine, but won't import into rc crew chief from csv, comes up as Motor Form sub getdata input not in correct format
Originally Posted by nexxus
(Post 14180192)
At the end of the CSV file there is 2 lines of extra information which needs to be removed.
Delete them and save the file. |
DamianW #dabest
Other than the link to RC crew chief, I find that the motor info presented here is very similar to the info that comes from my Fantom. One item is that there are many more samples but the Fantoms only presents it in .1 second steps. I have talked to the Fantom's software designer and he cautions on one issue. Brushless motors are fed their voltage around the poles electronically where as brushed motors are mechanically timed at the motor commutator. This creates problems with amp draw sampling and readings that are displayed. Has anyone delved into that potential issue with the Eagle? I have found with the Fantom that the data seems to be smoothed enough that it is not really an issue and pulling the motor a couple of times, if you want, will verify that.
I don't think any unit is going to be a 100% substitute for on track performance, but I also don't think a fantom software developer is an impartial opinion either. Of course he (or she) would talk up their product in comparison to the competition.
| All times are GMT -7. It is currently 11:39 AM. |
