LRP Rotor Problem
Hello,
I need help with two problems i have encountered dissambling my two LRP motors.
I have dissambled my LRP 8.5 motor because i hear a strange noise. I had installed in it a 12.0 rotor, and the magnet is slipping from the shaft. Is there any possibility to fix it? It is only the magnet which slip, the two light metal sides are solid with the shaft.
The other motor i have it is a LRP 7.5. I have checked it and i find that one of the sides of the 12.5 rotor is free. This motor has 2 hard racing years so i think it would be a high temperature use. I think that this motor has lost some punch since 2 years ago, but i donīt know if it would be because this problem i have discovered. In this case, the magnet is solid with the shaft.
George
George
