Orca Vxx Comp. Esc Problem >
Old 07-21-2015 | 03:37 AM
Hoschi1's Avatar
Default Orca Vxx Comp. Esc Problem
Hello Everybody,
I have a problem with my Orca Vxx Esc.
I use the Esc and a Orca Tx engine with 4.5 T.
At the weekend I drove 3 laps and suddenly the car stops.
The motor and Esc had a temperature of about 52 degrees.
The problem is that usually no more commands on the remote control respond.
The blue light flashes as normal otherwise.
I once again bound to the receiver and the Esc and the remote control.
Unfortunately, no change.
I just noticed that emits a high tone at a certain throttle position normally and the drive pinion moves very slightly (not much).
What could that be?
Hoschi1
Hoschi1 is offline
Old 07-21-2015 | 04:42 AM
dan_vector's Avatar
Sensor board on the motor or sensor lead. I'd try a different lead first then different motor if the lead didn't fix it.
Originally Posted by Hoschi1
Hello Everybody,
What could that be?
Hoschi1
dan_vector is offline
Old 07-21-2015 | 04:58 AM
Hoschi1's Avatar
Hi,
another sensor cable I've already tried. On the sensor Borad the engine I have to try.
I can still try to exchange engines.
thanks
The Esc has a mistake I hope not, or how is your assessment
Hoschi1 is offline
