Replacement ESC for Rustler
I need to replace the ESC in my VXL Rustler. Traxxas is about $55 to replace. Are there other ones I should look at that are comparable but less expensive? Motor is the stock VXL motor and works fine still.
Called then LHS to see if he had one of the quicruns in stock. He does but he said its not really the best replacement for the stock ESC. Technically not rated high enough for the stock motor. Have you guys been running these without problems?
Thanks for all the info. Appreciate the help.
Looked over the link. Is there any way to tell what motor it is without pulling it apart? The link shows the motor internals to show the difference.
I bought the rusty used so Im not really sure how old it is (or when they switched motors for that matter).
"The motor wires will have black mesh covering the wires and the part number on the end cap will be 3351r." It gets trickier with used trucks though - someone could have rewired it or the part number could be rubbed off the endbell.
However, your now deceased ESC itself should add the "-3s" to the vxl part on the sticker on it as well if you have the newer one.
