esc and lipo help needed >
Old 06-25-2015 | 11:28 AM
Default esc and lipo help needed
Hi all.
New to the forum so wold like to say hello,
Im currently running a bl cage, and using 4s lipo the current esc on the car is a hobbywing 80a.which goes quite well.
Im thinking of getting a 6s lipo would i need to change the esc to a 150a to use with that kind of lipo
Any help would be appreciated
thanks
madzook is offline
Old 06-25-2015 | 11:50 AM
MarkA's Avatar
All the HW 80a ESC's I'm familiar with are rated to a max of 4s so yes, you would need a new ESC to run 6s.
MarkA is offline
Old 06-25-2015 | 12:02 PM
thanks
would you recommend a esc for 6s lipo
madzook is offline
Old 06-25-2015 | 12:29 PM
MarkA's Avatar
If you're happy with your HobbyWing, there's no good reason to switch brands, especially if you already have the HW programmer.
MarkA is offline
Old 06-25-2015 | 02:32 PM
thanks
im just wondering if the standard motor will be able to cope with 6s lipo
madzook is offline
Old 06-25-2015 | 03:17 PM
mkiiina's Avatar
What car/motor are you running? All motors have limits on how fast they can spin before they let go.
mkiiina is offline
Old 06-27-2015 | 05:50 PM
Hi
sorry for late replying,
the car is a bl cage
just ordered Turnigy Trackstar 150A GenII esc
the motor is a 2370kv not sure if it will be up to it
madzook is offline
Old 06-28-2015 | 08:12 PM
Frank L's Avatar
2370kv on a 6s setup? That's insane. Usually most run 1400-1550 on 6s. You want to keep the end value around 30k=volts x KV
Unless you are just bashing then I get the over powered beast
Frank L is offline
Old 06-29-2015 | 02:57 PM
thanks esc came today set up with stock motor running well shredding the tyres
motor seems to get very hot so looking for a better motor what would you recommend would the 1 below be up to the job or would i need a better one
thanks all
Andy
Turnigy XK3665-1200KV Sensorless Inrunner
Spec.:
Poles: 4
KV: 1200
Max Current: 54A
Max Voltage: 29.4V/7S Lipo
Case Length: 65.5mm
Case Dia: 36mm
Shaft Dia: 5.0mm
Total Length: 85.2mm
Weight: 275g
madzook is offline
